AX speedo cable failed!
x 3277
How do all!
A family friend on the Isle of Wight has had the speedo cable failed. She has an M reg 1.1 petrol AX, and it uses the one piece cable. She has been quoted £200 (part and labour). The garage have said that they can only get the cable from Citroen, for £100 (Ouch!), and that it is a 4 hour job (so not a bad labour charge). I have looked on GSF and ECP, and they don't have the cables. However, she is having to save up to have this done. Can anybody help her on this. I have lent her my old Sat Nav so she can see her speed, but it is a bit of a bodge.
Chris570
x 37
Re: AX speedo cable failed!
Unread post by Chris570 »
you can quite easily convert it to electric speedo using the saxo mk1 dash pod and electric sender on the gearbox.
I believe the pin on the dash pod for the signal is on the blue plug and is pin 4.
Setting up the feeds to the plug on the gearbox is very easy as well.
I used to convert AX's in about one hour, all in.
If you go down that route let me know and i'll dig out all the info.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
x 94
Unread post by citronut »
here is price and part No. for the only one piece cable listed for an AX on service citroen
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00006123J4 SPEEDOMET CABLE 33.12 GBP 39.74 GBP 39.74 GBP
both the others shown are two piece,
if you get the last 8 digits of the chassis/VIN No. i will get specific for the car
Regards, malcolm.
x 3277
Thanks gents, I have passed on the information. I will let you know what is decided.
x 1238
Unread post by Peter.N. »
I don't know if 'Speedy Cables' are still going, I heard they were fairly recently, they will make a cable for anything. Used them in the '50s!
geoneeta
New User
Unread post by geoneeta »
Chris570 wrote:you can quite easily convert it to electric speedo using the saxo mk1 dash pod and electric sender on the gearbox.
Hi
Can you send me the info about this conversion please, Thank you.
