hi guys.been a while since i on here coz everything has been going great
and still is.just wondering does anyone know of a quick and easy way to
get the stains of suncream lotion off the paint work of the car.it looks
horrid and whatever scrubbing i do,it does no good.any ideas anyone.
thanks
c5 paint work
Timmo
- x 168
Re: c5 paint work
Chances are that its the oils in the suncream that jave soaked into the clear coat, it is a Real pain in the bum to remove, firstly try baby wipes, they are very good for this sort of thing, failing that neat fairy on the areas, if that doesnt shift it then thinners/panel wipe or Isopropyl alcohol, but be aware after them you will have unprotected paintwork, a quick splash of polish over the area will help!
Hope that helps.
Hope that helps.
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
Richard_C
- (Donor 2026)
- x 224
Re: c5 paint work
WD40 sometimes works as a solvent to shift stuff, worth a go after the baby wipes idea.
Richard_C
- x 2941
Re: c5 paint work
Talcum powder if it's oil in the lacquer, spread it on and let it lie for a while.
mm1
Re: c5 paint work
ok guys i will try all these options.i have alredy tried the wd40 and that did no good.
on a different note,the paint on my front drivers wing is all chipping off and i know
where there is a scrap car thats the same colour.is it a hard job to take off the wing
and fit it to my car?
Timmo
- x 168
Re: c5 paint work
Took me 15 mins to do it on the Xantia first time, just a case of finding all the bolts, shouldn't take too long to get off!
'58 C2 Code
'58 C2 Code
mm1
Re: c5 paint work
ah thanks very much.probably go down that route so,sounds easier than getting my
own one sprayed.thanks again
