I have problems with the radio I set the stations but when I press the switch on the steering wheel instead of going to the next station and stopping, after a few seconds it moves on to the next and so on can you help me please
allan
series 2 xantia radio
Timmo
- x 168
Re: series 2 xantia radio
mine does that, scans through the station presets, as it is, i normally leave mine on R2 unless its that political numpty Jeremy Vine!! just turn it down then!!
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 5671
Try pressing it again when it stops on the station you want (WAG - never listen to the radio).
allanmc
I appreciate you getting back to me but I was hoping for the cause and how to fix it
Allan
Allan
Xantia 2.0i SX Auto, 1999
- x 1449
The cause is: That is how they designed it, it is a memory scan function
The fixes are: a) press the button again on a station you like.
b) don't press the button in the first place.
Northern_Mike
There is no cause. That's how it's designed to work. I set the presets on mine and used the other button to move between them.allanmc wrote:I appreciate you getting back to me but I was hoping for the cause and how to fix it
Allan
allanmc
I dont think I am describing the fault properly, so here goes I had my other Xantia for 8years and to set the radio I scanned for stations and when it got to one I wanted I held the No. 1 button and the sound went away for a second then came back I then started again and did the same until I had 6 stations tuned in, then when I wanted to change stations I used the buttons on the steering wheel until I had the station I wanted and as I have said on this Xantia it just keeps moving from station to station, I hope this explains it a bit better and if I can just say I have the radio instructions that came with the car
allan
allan
Xaccers
- x 188
So if you press the button again it doesn't stop?allanmc wrote:I dont think I am describing the fault properly, so here goes I had my other Xantia for 8years and to set the radio I scanned for stations and when it got to one I wanted I held the No. 1 button and the sound went away for a second then came back I then started again and did the same until I had 6 stations tuned in, then when I wanted to change stations I used the buttons on the steering wheel until I had the station I wanted and as I have said on this Xantia it just keeps moving from station to station, I hope this explains it a bit better and if I can just say I have the radio instructions that came with the car
allan
DIY sphere tool
DIY sphere tool
Mandrake
- x 695
Agreed. Mine works exactly the same way.xantia_v6 wrote:The cause is: That is how they designed it, it is a memory scan function
It's not a bug its a feature!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Northern_Mike
I expect it does.Xac wrote:So if you press the button again it doesn't stop?allanmc wrote:
There's more buttons on the S2 car and they are different in operation. I can't remember which does which, but they are definitely not the same as the S1 car. Allan is pressing the button for scanning which does stop if you press it again, but there is another button, possibly the one you use to go to the next track in CD mode which skips between presets.
allanmc
back again both cars are series 2 so I thought both radios would work the same but they don't as you said Zac pressed the button again when it get's to the station and it works thanks for that
allan
allan
