my L reg xantia has just had a new clutch fitted.
everything was fine at first but now it is getting increasingley hard to get into gear.
can I adjust this and if so how?
It is a 1.9 td
thanks
xantia clutch
- x 1477
TD uses an inside-out clutch which makes the biting point near the top of the travel. If you are not getting enough travel the clutch will not disengage. The book says 140mm (IIRC, which I probably don't!) of pedal travel, but I think this is OTT for the TD. You should be able to adjust the cable - do it so that you get enough pedal movement to change gear cleanly.
If it was only changed 3 weeks ago, I'd take it back to where it was done and get them to adjust it properly!
Richard
Richard
mbunting
Kowalski
mbunting
From experience, check the high pressure hydraulic pipes are not fouling the gear selection mechanism. "5th gear will get better with wear, sir" was thier diagnosis !
Aparently, leaving the selector rods bone dry is the done thing as well, no grease needed there, unless you want a proper job and easy gear selection.
Be rest assured that the pool of hydraulic fluid was there before your car.
[:0][:(!][:0][:(!][:0][:(!]
