also my pass window only moves a bit at a time and opens on its own with the wipers on , is this a common problem?? its a 2002 c5 , thanks
rear arm bearings again
rodney
hi people , couple of things , 1st is am I right in thinking the rear arm bearings are the same between the c5 , xantia , bx and c15 van??
- x 1996
Re: rear arm bearings again
http://www.frenchcarforum.co.uk/forum/v ... =3&t=46540" onclick="window.open(this.href);return false;
- x 94
the only bits the C5 shares with the BX, CX, C15 and XANT are the bearing and the seals, the rest of the parts are peculiar to the C5, ie he spacer bushes and tube,
no good buying the usual are bearing kit, you can buy the bearing and the seals from GSF then the rest from the dealer
Regards, malcolm.
