solenoid starter motor (no conntact)
ektor
Unread post by ektor »
I have a problem im the starter motor.The problem is in the part,( no conntact together) I have signed in the picture.How can I resolve it?
x 94
Re: solenoid starter motor (no conntact)
Unread post by citronut »
have you check the motor brush's are in good condition and making firm contact with the commutator,
as i have always been told a brush contact problem can cause the solenoid circuit to not function properly,
if the brush's are good then it could be the trow in or hold in windings of the solenoid have failed internally
Regards, malcolm.
ektor
how can I resolve the problem please
x 1240
Unread post by Peter.N. »
Malcolm is correct, one of the solenoid windings is in series with the motor. Fit a new pair of brushes if possible or check that they are not stuck or greasy.
