Xantia - Anti sink valve O-ring leaking
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
This is a correction for my post about a leaking union. I fount out that it is the front anti sink valve that is located below the Doser. I detached it and found out the there is an O-ring that causes the leaking. Can this O-ring be bought from Citroen ?
The car is Citroen Xantia 2.0 16V automatic make year 2000
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 94
Re: Xantia - Anti sink valve O-ring leaking
Unread post by citronut »
citroen dont list the/an O ring specifically for the anti sink valve, but i think one of the two different O rings for the hydraulic pump are the correct dimensions,
part No.'s and dimensions below
4026 87
HYDRAULIC OIL O-RING SEAL
DIAM 16-TO 1,9
- DIESEL XU
£1.62 inc VAT each
4026 88
DIAM 19-TO 2,4
- DIESEL XU
£1.38 inc VAT each
i think you can only buy them in packs of 5
Regards, malcolm.
x 94
ps.
this seal can be replaced in situe
Regards, malcolm.
lancia58
(Donor 2022)
x 8
Hi
Thanks I did it in situe and the leak stops
Zohar
