briton 240 104
crutts
briton 240 104
Unread post by crutts »
I have this relay sat in my ecu box . What is it for? Thought it might be the aircon relay. It's on a 98 de xantia
Gingerposer
x 6
Re: briton 240 104
Unread post by Gingerposer »
A quick search on the forum for "Bitron" sensor will shed more light in it than I can - it's something to do with the cooling fans and aircon system.
crutts
Re: briton 240 104
Cheers that's what I hoped it was
Mandrake
x 694
Re: briton 240 104
Unread post by Mandrake »
"Bitron" is the name of a company who make electrical components, not a specific component. They make a controller for the radiator fans in the Xantia but it doesn't sit in the ECU housing, its elsewhere, under the left headlight on many models of Xantia.
The "Bitron" in the ECU housing is the double injection relay - it's used for turning on power to the ECU, fuel pump, coil packs, injectors etc when the ignition is turned on. Some Xantias (like my V6) have two of them in the ECU housing, some have one.
What's your exact model of Xantia, and what is the problem you're trying to fix ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
crutts
Re: briton 240 104
Hi Simon, Thanks for the reply.
The xantia temp gauge goes up when other items are switched on ,, lights, heated rear screen, blower. I have read other posts on the forum and have done what the have sugguested ...clean earths, replace temp probe (Blue one) which was found to be faulty. Car never overheats, blows warm air and fans work, (both come on when they should)
I have been told that the Air con relay is stuck open and if thats a possible cause i was trying to trace it. In the EC box there is the Briton unit i mentioned and a green socket with a green four pinned relay plugged into ,not sure what that is. I could send pics if that helps.
Hope this is clear!!!!!
Tim
