Hello. I've got a well loved Ph2 Xantia with 263k miles on it........ it's never missed a beat until now........ It all started last week when it refused to start, turned over fine but wouldn't fire. Because it's only the work hack, i left it and took our other car. Next day just incase, i put a jump pack on it and she fired straight away and ran fine. Rushing around with it the last few days, i've let the fuel run low and today, i started the car and went to pull off and it lacked power drastically. I turned the engine off and restarted it. This time i got the dreaded engine management light and wouldn't rev over 2200 rpm ( limp mode? ). I have the grace of having my own Lexia, so i stuck it on and got these faults:
1. INTERMITTENT FAULT
DOUBLE RELAY CONTROL SHORT CIRCUIT TO -VE OR OPEN CIRCUIT
2. INTERMITTENT FAULT
INLET MANIFOLD PRESSURE SENSOR COHERENCE WITH ATMOSPHERIC PRESSURE
3.INTERMITTENT FAULT
FUEL PUMP SUPPLY SHORT CIRCUIT TO -VE OR OPEN CIRCUIT
I tried to clear these faults but they won't clear down
. As a precaution i have changed the fuel filter and although it remains in the same state, i can drive the car and it seems to rev past 2200 rpm.
Any ideas to help me keep my Xantia on the road would be very greatly received
