Inside Out is a show on the BBC that maybe some of you are familiar with, as it has different editions for the areas it is broadcast in.
Apparently the one that will be on next week, in the London area will be doing a feature on the popularity of the Ace Cafe, and all sorts of event have taken place there, including Citroen holding a birthday celebration there.
So if you feel like watching it, and (can) get the London signal, then it should be on the TV next Monday.
Otherwise it might be shown in the regions, if the BBC want to let other areas see it, although if they don't then you should be able to see it here...............
http://www.bbc.co.uk/programmes/b0071mkv" onclick="window.open(this.href);return false;
Inside Out
Inside Out
ACTIVA
Re: Inside Out
or through iplayer maybe
Regards, malcolm.
Re: Inside Out
The programme is on @ 1930hrs on Monday 28th October 2013 it will obviously be available on iplayer soon after airing on the TV, and in effect the link posted above is a connection to the iplayer if you read the information on it.
Here's a further link from Inside Out, which lists the episodes including the one about the Ace Cafe.
http://www.bbc.co.uk/programmes/b0071mk ... ts/2013/10" onclick="window.open(this.href);return false;
ACTIVA
