Xantia estate tailgate
pete the bus
Hi, can anyone tell me please if a S2 tailgate for a Xantia estate will fit onto a S1? Many thanks.
- x 94
Re: Xantia estate tailgate
i dont see why not,
but if you need a MK1 tailgate i will be sending my XANT estate to meet its make soon, if you require it i would need your old one to put back in the hole,
my one is white
my one is white
Regards, malcolm.
- x 94
Pete
i have sent you a reply in your post in sales and wanted
Regards, malcolm.
pete the bus
Cheers Malcolm. I have a 1997 (P) S1 estate with a smashed rear window. There is a S2 (W) at a breakers near to me with a good condition tailgate with window. They want £30 for the complete tailgate. If I can be assured it will slot straight in then I will get it tomorrow...
If not then I will be interested in claiming the one from your breaker.
- x 94
i just did an all families search on service citroen both ways with part No.'s from MK1 and 2 which are different No.'s,
and one dose not go over to the other, so not sure what the difference's are
Regards, malcolm.
pete the bus
Thanks for that, Malcolm. So, just to confirm, the S2 tailgate WILL NOT fit the S1? I don't mind if there are cosmetic differences, so long as it physically fits...
Old-Guy
- x 24
I've not checked, so I have to believe Malcolm, but I'm very surprised as I understood that apart from the nose, there are no significant differences between S1 and S2 bodywork.
I learn something new every day.
pete the bus
I have been to the breakers today and have successfully swapped the tailgate from the S2 into my S1. Result! Dimensions are exactly the same for both. Wiring loom seems identical too. The only differences I can see are the wiper arm is arranged differently and some differences in the trim.
i haven't completed the wiring and trim yet. Getting the top stop light wiring and rubber pipe for the washer along the inside of the tailgate looks like it's going to present some problems. Anyone have any ideas how best to do it?
- x 94
good to hear the MK2 tailgate fitted,
i dont know differences there are but below is the two different part No.'s
MK1 part No.
8701 F3
MK2 part No.
8701 J5
MK1 part No.
8701 F3
MK2 part No.
8701 J5
Regards, malcolm.
pete the bus
I think another difference is the S1 has a barrel lock for a key, whereas the S2 doesn't and is locked by the central locking only.
