2002 c5 hdi cutting out problem,.
rodney
Unread post by rodney »
heres the deal , I bought a citroen c5 hdi yesterday , been mint all day , tonight I take the fuel pump out the tank to look at the gauge sender , put it back and it starts fine , get 10 mins up the road and the eml comes on and the car cuts out ,
I have to lock and unlock on remote to get it to start but the eml stays on , then it runs for a shorter time each time before it cuts out,
anyone know if the pump in the tank needs calibrating??,
I admit I did turn the engine over for a second with the tank pump unplugged , but started straight away when reconnected again ,
any ideas people?? thanks :)
citroenxm
Fallen Hero
x 70
Re: 2002 c5 hdi cutting out problem,.
Unread post by citroenxm »
No they shouldn't need any calibrating..
A very sad...
1994 XM 2.1 d auto
coastline taxis
Unread post by coastline taxis »
why did you take the pump out in the first place as its not the run of the mill thing you check on a car
rodney
to check the fuel sender as the fuel gauge seemed to be playing up,.
coastline taxis
A I see. if you leave the ignition on or when filling up the gauge tends to not move until the key has been taking out and the put back in
x 1240
Unread post by Peter.N. »
Is it a 2.0. or 2.2?
rodney
its the 2.0
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
think we are going to need a special 'HDi October problem forum' at this rate.., is that 4 now that are failing as of a week or two ago,,,
great engines but,,,
A description of all the parts on the fuel system, the expected Lexia readings of good parts, common methods to try and pinpoint problems etc etc
J
rodney
well I tried plugging it in to a code reader and neither I tried would work with the car ,
I have a 206 hdi for parts,
so I tried the tanks fuel pump , the same
cam senser , the same
fuel rail , the same
its at the point it wont come out a limp mode and is running approx. 5 seconds before it cuts out till you lock and unlock , that wont even always work 1st time,.
jgra1
(Donor 2021)
x 36
whereabouts are you Rodney?
rodney
im north London mate near the ace,.
jgra1
(Donor 2021)
x 36
ahh ok.. someone near there may have the correct Diagnostic eqt .. there is a map on the forum.. I in a rush now ..someone else will pinpoint it ;)
rodney
im in the trade so can get get to a machine but its getting there as I have no car on the road lol,.
rodney
just had the aa out so they can plug it in , swapped fpr then cleared codes and was fine for 5 mins then started again :(
