suspension Xantia 1.9td
ned
Unread post by ned »
when putting the lever in the normal driving position the rear of the car seems to be very high does anyone have any suggestions to what the problem may be and how to rectify it[?].
thanks for any advice[:)].
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Probably the rear height corrector is stuck or the link lever has come off. What happens when you move the height adjustment from low to high?
ned
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JohnD</i>
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">the height is the same as when in normal.
also when the engine is turned off the the car height doesn't drop
