Looked a bit closer at the HDi90 thats in for breaking... Its one of the odd batch of cars with the larger unions on 3.5mm pipes At the STRUT end only from the looks of it..
This is what they look like...
This is all I can offer at the moment..
C.Morewoods Odd Strut unions
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
Re: C.Morwoods Odd Strut unions
It's MorEwood Paul:-)
Once I get hold of these I'll go along to some of the suppliers in Aberdeen and see if they are a stock item.. or at least can be got hold of easily..If not I'll make upnew pipes for my car and have the others on loan to members.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
Re: C.Morewoods Odd Strut unions
Oooppps. it is sorry.. corrected now.
Do you want me to save the pipes or litterally just the unions?
Whats the harm of making your own? Not sure what the thread pitch or size is but if a bolt the same size can be found whats the harm in drilling a 3.5mm hole through it.. then flaring your own pipe after. Im gonna try that for the other set of strut tops and make some adapter pipes for them to sell on..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
Well Paul I thought it might be easier to get just the unions sent up here.
I had ordered a new pipe... yes I found one, from a dealer but having orderd it from his supplier , it arrived damaged and had to be sent back.
So I thought just sending the unions in the post would minimise the chance for damage and also allow me to have new pipes which i would coat with some shrink plastic to protect them?
I never thought of making my own.
I take it that the RPO was within the accepted range? You said you were going to make sure Monday.
Off up to Shetland for a couple of days from Wed so I won't be able to reply from then till Sat.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- Donor 2023
I believe Paul has discovered that the odd pipe unions fitted to Xantia suspension cylinders RPO 8209 -8518 are a standard fit on C5's
I'm multi posting this just in case it can help someone searching in the future
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
I only did a visual on the struts Chris..
I removed your unions today.... What lies behind the union is gonna make them ummm unique and un makeable again!
I think the way to go on these small batch of cars for the future is to swap the rear cylinders back to older types..
Heres why...
YES, it is what you see! NO thats NOT a rubber seal! Yes thats a small nylon end seal, and YES that pipe end is flared at the tip!
The pipe came out like that... the metal "Block" is a VERY tight fit on the pipe, I had to grip it with pliers before the pipe would turn in it..
There NO rubber seal. and, heres the view inside of the strut pipe orface...
So, im not sure what to make of it... me? Id be inclined to change the rear struts back to older ones, and standard compatability...
Heres why...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
Thats different to my fittings Paul I just have a small black O ring at the bottom, which is a pig if you loose it and really difficult to seat in the cylinder opening as it faces downwards and always wants to drop out... I guess they've changed the design again.
So we need to have a donor C5 to really check Paul? I'll see what I can find.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
Could that O ring be whats left in the cylinder???
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
Yes that could be it.. sorry hadn't looked at that pic.
Apologies for "jumping the gun"
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
The mk1 c5 hdi90 hatch rear pipes are nothing like those pics above I can say from my own hated experience.
