2004 Picasso Auto Brake pedal switch
ldare2000
x 4
Unread post by ldare2000 »
Ive a 2004 Auto Picasso. My brake light is stuck on and I know its the switch as when I raise the pedal back up, only a few mm of play, the lights go out. From searching this is a common fault with Picassos.
Ive removed the felt buf can't see any switch? As this is an Auto, ie no clutch, I suspect the set up may be a bit different down below. Any suggestions?
Louis
