Xsara Picasso climate control illumination
Dave77
- New User
Can anyone help. I have 56 xsara Picasso and the bulb has blown on my climate control panel so I cant see if the air con/heated rear screen is on or off. I have spoken to a Citroen main dealer and they told me that it is a labour intensive job. I have dabbled with my Picasso. So can anyone shed any light on my dilemma to avoid enormous expense.
Lighty
- x 35
Re: Xsara Picasso climate control illumination
It is not that hard, if you remove the gear stick surround (triangular) and the radio(two screws) the screws that hold the facia on are revealed. I think the climate control versions are a bit harder than the normal, but 40 mins should see it through easily enough.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Dave77
- New User
Thanks for your reply. I assume the two plates alongside the radio remove showing screws? and then the radio removal will become apparent?
Bingohora
Hello. I have the same issue/it all works just black! Did you find a solution?
