Dispatch 2007 1.6 Hdi gearbox Fluid.
panda666uk
Unread post by panda666uk »
Noob Question I know ! but where do you top up the gearbox oil on a 1.6 Hdi 5 speed Dispatch 2007 gearbox ?.
Cheers.
x 94
Re: Dispatch 2007 1.6 Hdi gearbox Fluid.
Unread post by citronut »
if its the same as most other PSA box's, you fill it through the breather/vent on top of the box just beneath the battery tray,
usually a 17mm plastic plug you remove it has a small cap sitting in the top of it
Regards, malcolm.
