Hi All
My new Pug 306 Diesel HDi is perfect. It seems to tick over a bit faster than my previous car at about 1100. Does anyone know what the normal rate is and is it easy to turn down?
Ste
Pug 306 Tick Over RPM
- x 1240
Re: Pug 306 Tick Over RPM
That does sound fast, I think mine run at about 800 rpm. There is no mechanical idle adjustment as the injection is electronic, may be possible to adjust it but you would need a Lexia. Does it have a throttle cable leading to the pot, if so it could be sticking or out of adjustment.
Gibbo_Wirral
It should start around that when cold then drop down when warm. A faulty MAF could be the culprit (and won't show an engine warning light).
Planet should tell you more.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
