Wheel Bearing
x 1980
Wheel Bearing
Unread post by Stickyfinger »
Hi
Getting a roar (no vibration) on a right hand corner, like tire roar but more...suspect wheel bearing on the way out. (Just changed the disks as well :( )
Can you suggest, 1st, it looks like a home job, is it ? (I don't have a press but I do have a hammer), 2nd any tips or "special tools I will need. Pains say joint splitter, hub puller
Best source ? for bearings.
C5 as below
Chlorate
Re: Wheel Bearing
Unread post by Chlorate »
A press is very recommended to get the new bearing back in again, they can be a real 'mare to get out.
If it's a front bearing you shouldn't need a hub puller since the hubs press fit into the bearing. I'd recommend highly getting a good pair of circlip pliers and some plus gas. When changing the front hub bearings on my ZX the worst part of the job was getting the poxy retaining circlip out.
Getting the upright (hub carrier) off is quite an easy home job if it hasn't all rusted together into a singular lump of kack yet.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
x 1980
Re: Wheel Bearing
Thanks for that m8....makes me feel a bit better about taking on the job ...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I like to build up a set of changeover hub carriers when the basic item is cheap and available. Then you're just faced with a swap, rather than racing the clock while stuck bearings laugh at you.
All hail the Alfa 147 with its bolt-in front wheel bearing carrier. They sure got that right.
x 1980
Re: Wheel Bearing
OK, had it jacked up, pulled the wheel top/.bottom/ rocked side2side....zero movement
Took off wheel, crowbar in....cant see any movement !
Wheel back on, thought it best to ask first
So, what else could cause a roar when going round right hand corners only ?.....me big time scratch headie
addo
x 95
Degrading wishbone bushes, transmitting more bearing noise and disc scuffing sounds to the chassis. Check your caliper slides freely as well.
x 1980
Re: Wheel Bearing
Hi
Checked disks and calipers, new disks and pads about a month ago, Wheel spins free & no "drag marks" on the disk, caliper works OK and even, handbrake is fine on 5 clicks and retracts really well (considering the stupid design). It is not a drag type noise, more like increased tire rumble. (yes I have checked the pressures)
Its in for a garage service next week, I will see if it gets worse over the next few days and I will get them to check the bushes. Funny how it is only on the right hand bends it is evident.
