New (to me) Xsara Hatchback, sticky accelerator!
Gingerposer
x 6
Unread post by Gingerposer »
Chaps, I am now the owner of my Dad's Xsara hatchback (he inherited a poxhall astra!) and there are naturally a few issues I want to work through, with your guidance :) I hope.
Main thing at the moment is a slightly sticky accelerator pedal - it doesn't move smoothly as I press it but instead goes in small jerks. Which naturally makes it a little difficult to drive smoothly. Any pointers as to what is likely to be causing this?
Cheers
Ainslie
rob_s
New User
Re: New (to me) Xsara Hatchback, sticky accelerator!
Unread post by rob_s »
Hi
More than likely itll be the cable frayed on the inside somwhere causing resistence
Change the cable out and shoukd be fine after that
Had quite a few like this/ snap! Useually at the worst possible moments ie over taking lol
Quite common and easy to change, new cable is around 10-15 from most motor factors :)
