Parrot 9200
eddyc
Parrot 9200
Unread post by eddyc »
Hi folks ive just bought a 2nd hand parrot 9200 system and its come with no instructions so im looking for any tips for installing it into our 2005 c5 1.6 vtr with a standard cd player.
Thanks in advance
Sent from my GT-N7100 using Tapatalk 2
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I'm fairly sure Parrot's website has the installation destructions in PDF form for all their products.
x 1998
Re: Parrot 9200
Unread post by Stickyfinger »
Does this help >??...more options on the site dependent on if you have a European Blue of African grey Parrot :)
http://www.nexxia.co.uk/products.asp?s= ... ot%20Leads" onclick="window.open(this.href);return false;
SaabC5
Re: Parrot 9200
Unread post by SaabC5 »
Beautiful plummage. :wink:
citroenxm
Fallen Hero
x 70
Re: Parrot 9200
Unread post by citroenxm »
Depending which model that actually is, I think you will need a Unit to Radio adapter for connecting it to the radio as the later C5 use a different connection to standard ISO connections..
A very sad...
1994 XM 2.1 d auto
Tikki
Re: Parrot 9200
Unread post by Tikki »
I had to connect my parrot handsfree to the cd player. It was deliverd with a Y stick/plug. Plug one in the car cd-cable plugg. Then You have to Pcs one for parrot and the last one for cd player. Tja parrot was just plug and play.
eddyc
Re: Parrot 9200
Well all the wiring finally arrived and I tried fitting it and nothing I cant get it to go it says in the instructions that in some cars I may need to add an ignition live did anyone else have this problem its a standard rd4 cd player
qprdude
x 14
Re: Parrot 9200
Unread post by qprdude »
I fitted the same model to a Rover 75. Pulled the radio out and followed the colour coded cable instructions if I remember there was a cable and adapter plug to fit a socket in the back of the radio to allow the steering wheel controls to work. I glued the twin microphones to a little spot above the ashtray. There was a cable for an MP3 connection which I fed through the centre console to the rear ashtray area. I don't think I ever got the radio to "mute" when a call came in like the factory fit though.
I have some photos of the wiring at the back of the Rover radio but I don't know how relevant they would be.
Rick.
2013 Citroen DS 5 D/Sport
falling-out-with-my-car
x 25
Re: Parrot 9200
Unread post by falling-out-with-my-car »
Stickyfinger wrote:Does this help >??...more options on the site dependent on if you have a European Blue of African grey Parrot :)
Isn't that the Norweigeon Blue pineing for the fiords???? :roll:
x 1998
Re: Parrot 9200
Nope...that is Freddie, he is a good lad of 16 1/2 years, a great friend but like a lot of teenagers he really is very naughty at times :)
really....he was saved form some total idiots about 12 years ago....they kept him alone in a small cage in a drafty porch !...bastar@@s
x 3303
Re: Parrot 9200
Well, Freddie is a magnificent looking person. Are you planning on bringing him (assuming that he is a he) to any of the rallies next year. I feel certain that he would be made most welcome!
x 25
Re: Parrot 9200
yes who needs a car alarm anyway?
I knew of someone who kept an african grey on a perch on the parcel shelf of his car whilst he was doing volenteer driving at the hospital, apparently someone broke into his car and the culprit was collered in A & E having stiches done to the back of his hand
after the parrot ripped a chunk of flesh from his hand and burst a main vein, the old passengers never got bitten by the parrot because the owner was always present when they got in the car the parrot was clever enough to know who was good and who was bad.
the bird raised the alarm to attract attention that someone unknown had tried to get in the car,
and people say "bird brain" meanning Dumb. how wrong could they be.
x 1998
Re: Parrot 9200
Hell Razor5543 wrote:Well, Freddie is a magnificent looking person. Are you planning on bringing him (assuming that he is a he) to any of the rallies next year. I feel certain that he would be made most welcome!
He only goes outside in the summer, as he was in a drafty porch he has Asama !...yep we have to boil a kettle under him (moisture) when he has a coughing session....stayed up all night a few times to help him out :(, as said Bast@@Ds
And yep....he can bite really good....but he has never done more than a pissed off nip......but you just know that little finger would come off PDQ !.
I can communicate with him far better than any dog I have had incld the collie and terrier....he knows you know :)
x 3303
Re: Parrot 9200
My cousin, Ailsa, has a Blue Headed Parrot named Ziggy. He also is asthmatic, and Ailsa helps him by smearing a little bit of Vaseline by his nostrils (which then traps most dust heading that way). He loves monkey nuts, but if they are dusty he then leaves them in his water container for a few minutes, and that sorts out the dust. He worked that trick out by himself.
