dashboard bulbs
froggy
(Donor 2026)
x 4
dashboard bulbs
Unread post by froggy »
Hi, my series 1 Xantia , TD. The bulb or bulbs that illuminate the heater controls has blown. How do I access this bulbs? is it a simple job to replace them? thanks in advance Terry. :?
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
citroenxm
Fallen Hero
x 70
Re: dashboard bulbs
Unread post by citroenxm »
Remove the radio surround trim.. two screws at the bottom obscured by the top of the ash tray..
Remove the radio..
Pop the plastic cover off the top of the heater panel.. you might need to remove the four screws for the heater panel to help access.. after the top is removed follow the small wires to the bulb holder which is a long twin lamp holder.. its a fiddle to remove and get back in place mainly the lower bulb is tricky to get back in place.
A very sad...
1994 XM 2.1 d auto
Xantidote
x 5
Re: dashboard bulbs
Unread post by Xantidote »
IIRC, and as Paul suggests, there are 2 bulbs, though you may not have noticed when the first one failed. Best renew both whilst you are in there
Martin
1995 Xantia TDLX (deceased :( )
oscar
x 8
Re: dashboard bulbs
Unread post by oscar »
Stick some led ones in and never have to redo they fit into holders like bulbs(W501's)
