Hi Guys,
On the 1.9 TD there were 2 bleed screws to release the air from the heating system.
1. at Matrix in engine bay
2. above/near to engine mount driverside.
Where are they on HDi 90 hp engine found the matrix one are there any others?
Kenny
BLEED OUTLET/S
KennyW
- x 164
BLEED OUTLET/S
C3 1.4 petrol (SWMBO)
- x 1484
Re: BLEED OUTLET/S
Should be one on the stat housing. If it's got an electric in line heater on the bulkhead, sort of above the flywheel, monitor this carefully during the bleeding run, as it's easy to cook it, and then it leaks.....
Rhothgar
- (Donor 2026)
- x 221
Re: BLEED OUTLET/S
TD what?
ZX has three! One up in the matrix hose.
KennyW
- x 164
Re: BLEED OUTLET/S
Rtothgar,
As per my signature 1.9 TD Xantia.
Thanks Richard, will pay attention to same.
Kenny
Kenny
Rhothgar
- (Donor 2026)
- x 221
Re: BLEED OUTLET/S
Sorry cannot see signatures in Tapatalk
Rhothgar
- (Donor 2026)
- x 221
Re: BLEED OUTLET/S
ZX is same engine.
