Xsara 3 door VTR 2.0 HDI turbo
CGATCX25GTITURBO
x 15
Unread post by CGATCX25GTITURBO »
Hi, would anyone know if these all use the same KKK03 turbo? and are there any short cuts to getting it off?
cheers
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
Stewart(oily)
x 35
Re: Xsara 3 door VTR 2.0 HDI turbo
Unread post by Stewart(oily) »
Its a few years since I replaced one on a 406 HDI, i remember that the 90 and 110 turbos seem interchangeable, only the outlet stub is different and surprisingly the bolts came out easily, not too bad a job IMO.
CGATCX25GTITURBO
x 15
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Lighty
x 35
Unread post by Lighty »
Same kind of job as a 306 if I remember correctly, it's a pig of a job, last time we did one, we removed the front subframe.
I think there may be more than 1 different manufacturer of turbos used.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
CGATCX25GTITURBO
x 15
Lighty wrote:Same kind of job as a 306 if I remember correctly, it's a pig of a job, last time we did one, we removed the front subframe.
That was my understanding thanks, I'd better get the old one off first then before replacement parts.
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
oscar
x 8
Unread post by oscar »
Hi from what i remember the 306/9boys went with the Garrett as more playable than KKK and durable
CGATCX25GTITURBO
x 15
oscar wrote:Hi from what i remember the 306/9boys went with the Garrett as more playable than KKK and durable
is it just a matter of choice then? all the other pipe work the same for either manufacturer?
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Stewart(oily)
x 35
I have swapped KKK for Garrett on XUDs you will need the appropriate oil feed and return pipes at least, I think the tuners only liked Garrett because it was a bit easier to tweak the wastegate, nothing in it as far as durability goes.
CGATCX25GTITURBO
x 15
Stewart(oily) wrote:I have swapped KKK for Garrett on XUDs you will need the appropriate oil feed and return pipes at least, I think the tuners only liked Garrett because it was a bit easier to tweak the wastegate, nothing in it as far as durability goes.
Thanks, it gets more interesting. I should be safe buying a KKK core unit then :)
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Im under the impression that HDi 90 and HDi 110 turbos are different. The outlet is in a different place and the HDi 90 uses an internal release pressure controlled wastegate, where the 110 turbos use a Vaccuum controlled by ECU via an electrovalve turbo, which defaults to WIDE OPEN waste gate if no vaccuum is applied to the wastegate end..
A very sad...
1994 XM 2.1 d auto
