Urgently needed - Instructions to change FILLER NECK SENSOR
paulcornwall
If you can help please do, I need instruction for replacing the FILLER NECK SENSOR on a Citroen C8, any links or help really appreciated.
- x 1987
Re: Urgently needed - Instructions to change FILLER NECK SEN
I don't have the full instructions but....if its the same as the C5 then you need a Lexia, do you have one ?. It gives the procedure for reactivating it.
You need about 5 gallons of fuel for the process as it seems to read a fuel increase during the process. Its a take off cap, wait, fuel, replace cap, wait 12 secs remove, replace ect..type of thing
Sorry I cant be accurate.....but it bumps the thread
