Making a pressure gauge
cc101
Unread post by cc101 »
Hi all, I'm making a pressure regulator tester and am after a few pointers on how to attach the pipe to the gauge, I've got a friend who's a welder. I've got plenty of Citroen pipe which have fittings on the end to screw into the pressure regulator. Any advice will be greatly appreciated.
Xantia 1.9 TD 1993 (sinker)
lankytim
Re: Making a pressure gauge
Unread post by lankytim »
I'd imagine somewhere like Pirtek could make an adaptor up easily enough.
Chlorate
Unread post by Chlorate »
If you know someone who has a lathe or a pillar drill you could make up something to do that in an afternoon. Just need to find out what the thread size is on the Citroen fitting and off you go.
Short piece of bar stock, drill all the way through, drill and tap 1/4" BSP thread in one side and the Citroen fitting size on the reg on the other.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
cc101
Could I just braze the pipe onto the bottom of the gauge?
x 94
Unread post by citronut »
cc101 wrote:Could I just braze the pipe onto the bottom of the gauge?
no reason why not, but obviously remove the fitting from the gauge beforehand
Regards, malcolm.
MJM
Unread post by MJM »
That's a glycerine damped gauge with a rubber seal visible in the photo. You need a mechanical joint onto it, brazing will damage it.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
x 1240
Unread post by Peter.N. »
If you go to your local plumbing supplier you will probably be able to get a fitting to screw on which will accommodate a small copper pipe, you could then solder a hydraulic pipe to it.
http://www.ebay.co.uk/itm/2-x-Genuine-P ... 27cf107706" onclick="window.open(this.href);return false;
cc101
Here's my finished result will test it after work and post a video of it in action!
Chris.
lankytim
Nice! Did you have the pipe made up? I would have been wary of brazing it. I'd imagine it would make a loud bang if the joint failed.
x 1987
Unread post by Stickyfinger »
Sorry to be a dumb one, but what would you need that for ??
Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
I think Jim's are brazed.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I would sleeve over the flex hose section with fuel hose or similar. With feed pressure it'll be quite stiff and I'd worry that flexing it may cause failure.
cc101
I had a local hydraulic specialist make it up for me with industrial fittings the rubber hose is good for up to 400 bar, charged me 15 quid to make it up!
addo
x 95
Be careful still, a tiny leak could do much damage.
