C5 rear suspension bush
Jeff
Unread post by Jeff »
I think I have a problem with a rear suspension bush. As anyone got any experience of this problem? The car has 114k on the clock. Thanks for any advice / help.
Currently driving Citroen c5 2.0 HDI 51 Plate
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Need a bit more information, if possible.
What year C5? What bush do you refer to? By bearing, do you mean wheel bearing?
Jeff
Re: C5 rear suspension bush
Citroen C5 2001 HDI 2.0
Off side rear swing arm bearing / bush
addo
x 95
Early one then - two bearings, shaft, crush tube and through bolt/nut. Estate may vary in bearing specs.
Try SNR KS566.05 or your friendly factors might plug that into TecDoc for an interchange.
x 1240
Unread post by Peter.N. »
I think you are referring to radius arm bearings, I have recently replaced them in mine. The bearing kit is about £60.00 per side but the cost of fitting them is largely down to how easily they come apart, the clips that locate the cylinder push rod can rust in and be very difficult to remove as can other parts.
You will need a press to extract the outer part of the bearing although it can be done with the aid of a welder. If you are not doing it yourself I would take it round and get a few estimates.
Jeff
Any idea on average time allocated to job?
addo
x 95
With a lift and no stuck pins I would imagine two hours drive in/out. Maybe 2 1/2. I'd quote four to be safe and possibly come in under estimated price.
x 1240
I did mine over a period of a few days but I must have spent four or five hours on it by the time I had everything unstuck.
Jeff
Does anyone know of a shortcut to a diagram that shows the rear suspension, ideally an exploded view?
Thanks everyone for your help.
addo
x 95
This actually shows a good overall image:
Jeff
Not literally exploded lol
x 1987
Unread post by Stickyfinger »
Jeff wrote:Not literally exploded lol
" onclick="window.open(this.href);return false; one way to get the pins out
Jeff
Has anybody knowledge of a plan of the rear suspension that shows all moving parts?
x 1987
If you have a Citroen dealer near by, if you ask nice with a smile, if the guy/woman is a nice person they might print it all off for you with the works/parts/times list....they do for me locally if I need it. ( Every now and then I purchase little bits to keep them happy}
Is this what you need ?
http://www.eurocarcare.net/rear-suspens ... r-kit.html" onclick="window.open(this.href);return false;
Jeff
Thats the kit I think..
I wanted to see plan to confirm problem.
