Door card and door rubbing strip clips
KP
x 27
Unread post by KP »
Does anyone have the part numbers at all so I can order some up please?
I can't get onto service citroen at the moment but it's for an interior door card and two outside rubbing strips on a xantia.
Also if someone could see what the clips are for an xm estate interior trim panel that sits at the rear of the head lining at the boot opening and keeps a 20" length of plastic attached that would be great :)
x 94
Re: Door card and door rubbing strip clips
Unread post by citronut »
here is price and part No. for XANT soor trim clip/s/hog ring,
although on the drawing it shows three options 7, 8, 9, the price is for No. 9
might help with last 8 digits of your chassis/VIN No.
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000696647 HOG RING 1.47 GBP 1.76 GBP 1.76 GBP
07
96 126 454
HOG RING
DIAM 17,5 TROU6,5H35
08
6999 CR
06
MKT CLIP
09
6966 47
HOG RING
price and part No. for exterior trim clip/hog ring
0000856535 HOG RING 0.11 GBP 0.13 GBP 0.13 GBP
and i think this is the XM roof rear interior roof/head lining trim clip/hog ring
00006991T0 HOG RING 0.19 GBP 0.23 GBP 0.23 GBP
Regards, malcolm.
KP
x 27
Unread post by KP »
Cheers Citronut.
Im not near the car at the minute but will do the VIN bit later when i get home :)
I just have to remove the drivers door card as the car won't lock with it in place at the moment so its a strip down jobby and the rear HC is stuck at normal ride height so some work to do before i put this xantia in for its MOT but fingers crossed the XM pass's today :D
