Xantia MK II – Replacing front left window regulator clip
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi All
I guess this is a common problem. I managed to get a new clip, is there a thread describing how to replace the clip , or anyone can post the instructions?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
harryp
(Donor 2022)
x 73
Re: Xantia MK II – Replacing front left window regulator cli
Unread post by harryp »
Hi Zohar, Haynes is not too bad on this. You need to raise window lift about half way in order to get enough flex on the glass to get it over the clip and through the rubber grommet. Then you have to push the spring clip through the grommet. Make sure that the grommet is positioned so that the clip goes through horizontal or slightly up or its a real pita. Also take care with the plastic guide that runs in the door seal. I broke one of mine not realising it was there and it is now attached using araldite! Keep the rear of the glass firmly back in contact towards the rear. It feels like it might - but I haven't broken the glass yet!!
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
MJM
Unread post by MJM »
Check the rubber bush that goes through the glass is in good condition and not split. They're available from Citroen in bags of 5 for about £5. I've got 4 new ones as spares somewhere, if you want one reply on this thread and I'll sort one out. I don't know where you got your new slider from but if it has a plastic retaining clip then the retaining clip won't fit through the window bush. I used the new wire one supplied with the bush. You have to bend it a bit to get a good fit on the slider. If you do a forum search using my name, MJM, then you should find more info. I've also got some photographs if they'll help.
MJM
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
