Can any body tell me what make of ECU in my C5 2.0 HDi 16v on 06 plate it's either Bosch or Siemens hoping it's Bosch for remap.
David
My C5's ECU
Diabolical
My C5's ECU
06 C5 2.0L HDi Exclusive Estate 20020k and rising.
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
citroencx.co.uk
Ben82
- x 7
Re: My C5's ECU
Post up the last 8 digits of your VIN and someone can look it up for you
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
SaabC5
Re: My C5's ECU
Pull the engine cover off and look at the injectors, if there's a series of rubber tubes going across the top of them all linked up you have Bosch, no tubes = Siemens.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1484
Re: My C5's ECU
Looks like only Siemens is listed against the injectors for 16V 2.0 engine.... But VIN may confirm.
Diabolical
Re: My C5's ECU
OK Vin 76743420
I had a look and could see no rubber tubes just wired plugs connected to injectors that had no make written on them, decided to look at the ECU took cover off no name written on the top and decided to much effort to remove ECU it to see.
citroencx.co.uk
citroencx.co.uk
JohnD
- x 72
Re: My C5's ECU
My C5 is Siemens and getting a remap done was no problem. The guy removed the ECU and took it into his workshop.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Diabolical
Re: My C5's ECU
Hi John
I may go for it after I've removed EGR and DPF I was hoping more for to be remapped on the car same time as shutting of depolution light, error.
Still @ 197k not sure worth it even though driving car you wouldn't think so.
David
I had it done that way with my Petrol TCT Xantia He had to remove the chip and replace with remapped one as they couldn't be re-flashed.JohnD wrote:My C5 is Siemens and getting a remap done was no problem. The guy removed the ECU and took it into his workshop.
David
citroencx.co.uk
citroencx.co.uk
JohnD
- x 72
Re: My C5's ECU
I had the DPF removed 18 months ago and again the guy had to remove the ECU and take it indoor to connect to his computer.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Diabolical
Re: My C5's ECU
That's interestingJohnD wrote:I had the DPF removed 18 months ago and again the guy had to remove the ECU and take it indoor to connect to his computer.
Did you notice much difference after the re mapping?
Do you know if he's still doing it and where he is based.
David
citroencx.co.uk
citroencx.co.uk
JohnD
- x 72
Re: My C5's ECU
I didn't notice much difference after the remap - that is until I hooked on my caravan. Then I did notice it. I was able to maintain 55-60 in 6th gear and the fuel consumption fell 3 or 4 mpg.Diabolical wrote: Did you notice much difference after the re mapping?
I remember driving off after the particle filter was removed. It was like having two engines. And I'm glad to say it still manages to get a quick pass on the MOT emissions.
The company I used for the remap was in Chessington, Surrey and the filter removal was done by a guy in Estbourne. If you need them, I can give you contact numbers.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Diabolical
Re: My C5's ECU
Thanks John
I may get back to you on the remap, however going to attempt
DPS friend & myself. Removing easy enough telling the ECU there isn't one the tricky bit.
citroencx.co.uk
citroencx.co.uk
