New oil but not plugs
Stempy
Unread post by Stempy »
So today I got around to spending a little fettling time on the old C5. First job, drained and refilled the autobox. I measured the out coming which was 4.2 litres so refilled with the same amount plus a little extra for losses in the draining and measuring process. Hopefully the level will be correct as getting to that level check plug is too much of a PITA without a lift, and I am yet to avail myself of a Lexia to check the correct temperature anyway.
Seems to drive fine and maybe a bit smoother on the changes, though I have to say that the oil that came out was pretty clean, which I suppose it should be after only 24,000 miles, even if it is 11 years old.
Next job was to change spark plugs. Sadly, in a senior moment, I had bought plugs for a Xantia V6 which are not the same as those for a C5. :oops: Worse was the fact that I had already removed the inlet manifold before I discovered my mistake. :roll: Still, it gave me the opportunity to clean the small amount of gum that had deposited in the throttle body.
I also have a fuel filter to fit but I can't find where it might be located, if indeed it has one. It is listed as a replacement part at GSF so I ordered one without checking first where it might be located. All references in the manuals appear to indicate it might be an optional fitment according to country, which seems a bit strange to me. Can anyone confirm this?
Another little problem that I spotted while crawling about was the central exhaust joint is a tad corroded and loose. Same spot where it happens on the Xantia at the centre box, so I will have to attend to that a bit sharpish before it falls apart.
Lexia ponce
x 1480
Re: New oil but not plugs
Looks like it's fitted only in cars specified for 'Dusty atmospheres' - post the last 8 digits of the VIN and we can check.
Stempy
76011752
Lexia ponce
Ben82
x 7
Unread post by Ben82 »
Yours doesn't have a fuel filter... mine over here in Sweden doesn't have one, and DHallworth's one doesn't either. (also checked your VIN to doublecheck).
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Stempy
Anyone want a fuel filter?
Lexia ponce
x 94
Unread post by citronut »
no sign of a fuel filter with your chassis No. on service citroen
Regards, malcolm.
