Early this year our Xantia V6 Exclusive had a drooping back end, which was diagnosed as a seized rear height adjuster. I had this cleaned and greased but now 3 months latter it is playing up again. Is there likely to be a component that needs replacing or is it just a question of cleaning and greasing again?
Thanks Chris
Xantia Rear Height Adjuster Stuck Again.
Six-cylinder
Citroen
1974 Ami 8 Break
1986 Visa 17RD, 1984 Cabriolet, 1983 652cc Special, 1983 GT
2000 C15D Club
1983 LNA Inca
1996 ZX TD Estate
1983 CX 2400
1978 GS
1972 DS
1997 XM 2.0 16v
1992 BX GTi 8v
1996 Xantia Activa
1974 Peugeot 504 cabriolet
1963 404 Saloon
1983 Renault 4 GTL
1974 Ami 8 Break
2000 C15D Club
1983 LNA Inca
1996 ZX TD Estate
1983 CX 2400
1978 GS
1972 DS
1997 XM 2.0 16v
1992 BX GTi 8v
1996 Xantia Activa
1963 404 Saloon
1983 Renault 4 GTL
- x 94
Re: Xantia Rear Height Adjuster Stuck Again.
was the height corrector cradle removed when it was freed off the last time, as the only way to fee these off long term is off the car,
then keep them greased
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Id agree with Malcolm, they really DO need removing from the car and the levers REALLY working loose again, then greased up well to keep them loose.
It is possible to remove the cradle without disconnecting the height corrector pipes etc BUT care is needed to be sure the "Prongs" of the lever sit in the exact CORRECT place on the height corrector "Arm" when reassembling..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
