Xantia Mk2 Alarm
xantiagreen
Xantia Mk2 Alarm
Unread post by xantiagreen »
Hi, Has the alarm on the Mark 2 xantia changed only as i owned a mark one and when the alarm was set off the horn siren and headlights were going off, but on my mark 2 forte just the siren and indicators go off. I'm thinking wiring or fuse/relay.
Can you get your alarm modifed to add the horn and flashing headlights
Thanks in advance.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
Mandrake
x 695
Re: Xantia Mk2 Alarm
Unread post by Mandrake »
On my series 2 exclusive only the Siren and indicators go off if the alarm is tripped.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Series two Alarms are programmed to operate in a different way.. when you reconnect the battery there is NO NEED to panic about resetting the alarm to prevent the siren going off..
Indicators only flash when unlocking them and blink once when locking it...
The siren will sound IF:
You lock the car with the PLIP, but then unlock the car with the key in the lock and open the door.
If - obviously - a window is broken ...
Or if you lock the car and have a faulty ultra sonic sensor in the car... (Press and hold the alarm siren button till the red LED on the door stays on permeanetly) this cancels the sensors on the doors...
A very sad...
1994 XM 2.1 d auto
