lights C5
Stempy
Re: lights
Does it have auto headlights?
Lexia ponce
Lexia ponce
waynedance
- x 8
Re: lights
Mine did this a few years back and it was the sensor in the windscreen had come loose.
Take of the rear view mirror by pushing it towards the dash, be careful as the mirror is attached by wires. This is how mine comes of but mine is the Exclusive with auto dim dip mirror, not sure of other models.
Hope that makes sense.
Volvo S80 D5.........
colin machin
- x 2004
waynedance
- x 8
Re: lights
I thought they all did as well, does it say auto on the light switch (button on the end)?
How else could the lights be coming on, on there own during the day?
OnlineRichardW
- x 1487
SaabC5
Re: lights
LX, base model never got auto lights and wipers.Stickyfinger wrote:I thought ALL C5s had auto lights ?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 2004
colin machin
Re: lights
head lights still come on on there own but go of when i turn on side lights only when ignition on and engine running.
C5 2007 HDI
waynedance
- x 8
Re: lights C5
Did you check to see if sensor was loose?
If not as said could be the comms unit.
Citroenmad
- x 110
Re: lights C5
As said, LX on both phase 1 and phase 2 C5s didn't have automatic lights. If its an LX and this is happening then its most likely the comms2000. If it has auto lights do as waynedance suggests. If that is ok try turning off the auto lights (with the ignition on, press and hold the end of the light stalk until it beeps) and see if they still turn on.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
waynedance
- x 8
Re: lights C5
Sorry did not read the posts properly, I guess you have a comms problem.
colin machin
Re: lights C5
wot do you mean by a comms problems at the moment wipers operat on there own radiator fan runs when engine cold and stop sign says stop and gauge reads very hot when engine temp is fine
C5 2007 HDI
citroenxm
- Fallen Hero
- x 70
Re: lights C5
Thats interesting thing Chris, If design is Base level, where does LX come in? Mums 2005 Phase 2 Design HAS got AUTO Lights..Citroenmad wrote:As said, LX on both phase 1 and phase 2 C5s didn't have automatic lights. If its an LX and this is happening then its most likely the comms2000. If it has auto lights do as waynedance suggests. If that is ok try turning off the auto lights (with the ignition on, press and hold the end of the light stalk until it beeps) and see if they still turn on.
The COMMS 2000 is the unit behind the steering wheel with the light and wiper stalks on it which also has the steering angle on it. Its common for playing up and causeing all sorts of issues.colin machin wrote:wot do you mean by a comms problems at the moment wipers operat on there own radiator fan runs when engine cold and stop sign says stop and gauge reads very hot when engine temp is fine
As for your Temp guage - that will be the Temp Sensor on the engine..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
