HDI pressure pump
beeplumber
HDI pressure pump
Unread post by beeplumber »
I have got a pump for my Xantia but it is missing the electrical fitting at the end.
can anyone tell me what it does and would it not working stop diesel getting to
the common rail. or is it a just a sensor.
thanks
Mik
BX
x 19
Re: HDI pressure pump
Unread post by BX »
Probably the pressure regulator. They are usually available from auto factors.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
It is the pressure regulator and they will if not finctioning properly stop fuel supply to the rail. Its a little like a gloryfied stop solinoid on an older xud engine pump.
They are available on their own at stupid money.. or like i did i got a whole second hand pump for 80 quid.
A very sad...
1994 XM 2.1 d auto
x 1240
Unread post by Peter.N. »
I got a secondhand one off ebay for not very much money, I fitted it but it turned out to be the pump so didn.t use it.
beeplumber
Thanks guys
Is there any way to test it don't won't to take the pump off if
it's just this that's faulty.
citroenxm
Fallen Hero
x 70
Urrmmmm no not really. Theres two torx 30 screws that hold it on.. then theres a small rubber O ring that holds it . It needs levering away gently..
A very sad...
1994 XM 2.1 d auto
