Just got a couple of problems happening with my 2004 2.0 HDi (110).
1. Loss of power when accelerating. I can coax the car gently and eventually it will reach a cruising speed, but car has no acceleration if i put my foot down hard (in fact it starts to slow down). I am sure i have seen this on the forum before, but cant find the thread. Is it the MAF sensor ?
2. Driving home one night recently, it was getting dark so i turned the side-lights on. The car then seemed to loose power (or brakes applied). After a couple of seconds this slowing down ceased and the car accelerated normally, however the STOP and red brake warning light came on. I have checked the brake fluid (fine) and the brakes seem to be working fine. This fault only now occurs when i put on the lights. Bad connection ?
I also have the usual anti pollution warning on continuously, but have got used to this now as it has been on for most of the time i have driven the car (18 months & 35000 miles), without any other side effects.
Help to point me in the right direction please.
Cheers
Simon Johnston
07429384206
C5 - Loss of power & brake warning light
kettlesimon
2004 C5 Estate 2.0 HDi
dnsey
- x 19
Re: C5 - Loss of power & brake warning light
If the anti-pollution light's been on that long, there's a good chance that the DPF is blocked.
kettlesimon
qprdude
- x 14
So why's the anti-pollution warning on? Does a blocked EGR cause this warning.
Either way, it's probably not the best idea to ignore it.
Rick.
2013 Citroen DS 5 D/Sport
- x 2941
Two possibilities to look at before lashing out any cash.
A very close inspection of the thin rubber vacuum pipes between the vac pump, the electro valves, the turbo actuator and the EGR valve, a tiny split in any of these will lose the vacuum and stop the turbo working.
A close look inside the MAF to see if one of the filaments has broken/dropped off, don't touch them or they will drop off, very delicate
- x 1484
1. Sounds like the MAF - a Lexia session will reveal how it's responding.
2. I'd check that you haven't got a twin filament bulb in the wrong way round - if the brakes are on, and you're trying to accelerate, it confuses the ECU - so if the side lights are putting the brake lights on too then this will cause that. Again, Lexia will point you in the direction.
- x 1240
Possibly an EGR clean would help, you can get a can of cleaner off ebay, you spray it into the air intake as per instructions, if it doesn't effect a cure it will certainly clean out the EGR valve and inlet manifold. There is no DPF on the 8 valve 2.0. Hdi.
