C5 Estate VTR+ DRL
C5chrisVTR+
C5 Estate VTR+ DRL
Unread post by C5chrisVTR+ »
Hi all
not long had my C5 and learning lots from this forum :) . I am trying to find someone near that has Lexia that would do me the honer of activating my DRL's, is there anyone in or near North Somerset that can help me out??
cheers.
Chris - North Somerset
C5 III 2008 VTR+ 2.0 HDI
x 3283
Re: C5 Estate VTR+ DRL
Hello there,
If you look on the following link, you will find a map of Lexia owners who are willing (and, probably, experienced enough) to help;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
x 1982
Unread post by Stickyfinger »
Got one but not even fully used it yet, it does however connect with my car and work (as far as I have got).......Nr Frome/Shepton
C5chrisVTR+
Stickyfinger you are the closets, the list does say there is one other person not to far away which is Andy F. in glos.
to be honest I don't have a clue with the software and have no idea how easy/hard it would be to work out?!?
x 1982
I will be happy for you to do what you need. If anybody could give guidance it might help.
If it is complicated, then a slightly longer run may be best....up to you your most welcome if you do come this way
BTW, whats a DRL :) ??....that is how BAD I am at it
Xantidote
x 5
Unread post by Xantidote »
DRL = Daytime Running Lights
Martin
1995 Xantia TDLX (deceased :( )
x 1982
ahhh :) thanks, did not know they could be switched on#
What year is the car ?
Edit
Does this help ?
http://www.auto-professionals.co.uk/sho ... 602#pid602" onclick="window.open(this.href);return false;
Andy F
x 8
Unread post by Andy F »
I am happy to give it a go and am reasonably confident using the software but its been a while. I have read and erased fault codes and done some actuator tests just to have a play. No promises but happy to try. Ill load it up over the weekend and remind myself how it works and see if i can find where the menus we need would be.
Andy
1999 Citroen Xantia 2.0 HDi 110 Estate
2001 Citroen Xantia 2.0 HDi 110 LX
1999 Citroen Xsara Picasso 2.0 HDi 90
1983 T25 VW camper
1994 Mini 1275 35th Anniversary Edition - sold
2007 C8 2.0 HDi 136 Exclusive - sold
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
x 3567
From a previous post on a similar subject:
"For those with a C5 III (X7) without the Daytime Running Lights option on their instrument panel...........
I've just had a quick session with my Diagbox and enabled the Daytime Running Lights via: BSI --> Repair --> Configuration --> Manual Configuration --> Customisation Customer. This has now put the DRL option onto the instrument panel and they work successfully. There are two options in the BSI for them: DRL on their own, or DRL plus sidelights.
Cheers,
Robin"
Hope that helps.
C5chrisVTR+
thanks for all your comments guys sounds great.
I have a C5 III (2008) and need the Daytime Running lights activating on my instrument panel as per bobins post.
i'll drop you a PM Stickyfinger maybe we can give it a try and failing that I can make the trip to Andy F. if that sounds ok..
