Adding Eolys fluid to C5 2.0 HDI
hamster99
Unread post by hamster99 »
Hi All
Can anyone point me in the direction of any guidance on refilling my C5 with eolys fluid. Where's the tank, how difficult is to get at, how much do I need etc.
Cheers
Rob
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
waynedance
x 8
Re: Adding Eolys fluid to C5 2.0 HDI
Unread post by waynedance »
I did my 2.2 mk1 last year and was quite easy.
I got 4 litres and the filling kit (bottle). The tank on mine was at the rear just before the rear wheel on the the left (near side) of the fuel tank. Remove the tin shield for access to the filling plug, remove the filling plug which on mine I think was green. The rest should be straight forward, I did make a small hole in the bottom of the filling bottle to aid it pouring into the main tank. I just held my finger over the end when refilling it, best to have someone helping.
Hope this helps, I did mine while on a ramp but should be fine with suspension on the high setting with wheel removed and on an axle stand.
Volvo S80 D5.........
micky707
Unread post by micky707 »
Where did you get the Eolys from? and how much, cheers
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
x 2941
I didn't think the C5 2.0 litre HDI had the eolys system
x 5648
Gibbo2286 wrote:I didn't think the C5 2.0 litre HDI had the eolys system
The early ones don't but I believe that it was introduced with the facelift.
Lighty
x 35
Unread post by Lighty »
Not saying his is the cheapest, personally I would have the dpf removed, but try searching for Pat fluid on Ebay
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
waynedance
x 8
Paid approx £90 - £100 for 4 litres. Euro car parts sell it.
waynedance
x 8
http://www.eurocarparts.com/mobile/spec ... d/patfluid" onclick="window.open(this.href);return false;
micky707
Unfortunatly and as far as i know if the vin has the 4 letters RHRH then it has a dpf, and mine has those letters. Only 48000 on the clock, so hope not to worry yet.
Micky
2 Pug 306's
Citroen ZX 1.9D
waynedance
x 8
I think the fluid is supposed to last approx 50k.
SaabC5
Unread post by SaabC5 »
This is the fill up port looking from the passenger side. The cover is hanging down after releasing 3 of the 4 fixings, its just a case of attaching the line and having the bottle/supply line higher than the filling port so it runs straight into the tank. You'll need rubber gloves as a very minimum but i'd recommend glasses and an apron as well, the Eolys is highly poisonous and a biohazard! :shock:
micky707
2.0HDI and 2.2, top up @ 80k and replace @ 120k
1.6HDI top up 75k and replace @ 87500
Micky
2 Pug 306's
Citroen ZX 1.9D
waynedance
x 8
Dam apron and gloves so that's why the tips of my fingers disappeared.
Xantianut
x 122
Unread post by Xantianut »
Ay up!
I'm confused. Nowt new there says Mrs XN!!
I have a '52 plate 2.0 HDi C5. Does this have a PF and Eolys tank? And how do I find out.
Always been a petrolhead, now a dieselnut!
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
x 5648
No, no Eolys/DPF
