205 brake problem
steviebx
205 brake problem
Unread post by steviebx »
i have a 205 diesel with a brake problem that's got me stumped if anyone can help me out with a few suggestions please?
good discs and pads but when the brakes are applied, depending how hard and at what speed, it feels like the braking action is being pumped.....on-off-on-off......the pedal pressure feels good and is constant and there's nothing loose underneath.........someone has suggested that i could have a problem with a vacuum pump diaphram but i know nothing about it....can anyone advise?
x 94
Re: 205 brake problem
Unread post by citronut »
sounds like warped discs to me,
this can be caused by binding brakes
Regards, malcolm.
x 1240
Unread post by Peter.N. »
I would concur.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Look for accretions of rust between the hub face and inside of disc. This interface needs to be spotless and lightly sealed with something like high temp grease.
