Hello I'm just wandering can you tell if a 306 hdi has been remap?
Is there away to check this also?
306 hdi remap
spider
- x 77
Re: 306 hdi remap
Visibly, well unless its got a "tuning box" which can sit between ECU and loom then no not easily. These don't always work as well as they should.
The other way was is to have the ECU flashed or one of the chips inside replaced. Not externally visible unless you wanted to take the ECU apart (not recommended)
Flash update not "visible" apart from checking values with Planet / Dyno test etc
Andy.
