berlingo interchangeable parts
john
Unread post by john »
does anyone know if any later 'lingo parts are compatible with a mk1? seats, dash etc?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
spider
x 77
Re: berlingo interchangeable parts
Unread post by spider »
Seats should fit OK. Do not forget to check out the Partner equivalent while "shopping" for spares.
Be aware later models may have side airbags in the seats and things like pretensioners for the buckle (if fitted not sure on these it might be in the belt instead) as these are likely to be different.
Later dash is different (round vents etc) , although physically it would bolt in the wiring would have to be removed from the old to the new and then it will not fit properly ie heater / old instrument panel would probably not fit the space etc.
Andy.
