help with dashboard warning light on a xantia
natace1972
Unread post by natace1972 »
it looks like a car with two skid marks behind it and color is orange what do this mean
cheers nat
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
It's the ABS warning light. When you first switch on it should light up, then go out. If it stays on it indicates a fault somewhere in the system. Tell us about it?
natace1972
from the top went to car last night to start and went into one alarm light etc went off and flatend the battery, jumped started this morn was driving ok but that light came on and stayed on and now batt flat again so going to full charge batt and se what happens
Homer
x 16
Unread post by Homer »
OK, let us know what happens.
Just one thing. I am British and English is my first language but your last post took quite a bit of working out. A lot of people who use this board, (especially some of the more knowledgable members) are not British and although their English is very good it will help immensely if you can make you posts clearer. We don't expect a literary masterpiece, just read through before hitting submit.
philhoward
Unread post by philhoward »
Reply in full english...
From the top..
I went to start the car last night, but it went into "one alarm light" (Immobiliser?) mode and flattened the battery.
I used another battery to start the car this morning and it drove fine, but the ABS light came on and stayed lit.
The battery is now flat again, so I shall charge the battery and see what happens.
