Gear box mount
Welshy_Pete
Gear box mount
Unread post by Welshy_Pete »
I've been looking at the mounts trying to work out which one it might be. I couldn't see much movement but after taking the battery tray out. I can see the gear box mount moving about when pushing the engine forwards and backwards so chances it will be this one?
Is there much movement on the gear box mount by hand?
306 hdi
x 94
Re: Gear box mount
Unread post by citronut »
what condition is your lower stabilizer bush/mount,
as this is the usual culprit
if its soaked in oil it will almost certainly have turned to jelly,
Regards, malcolm.
spider
x 77
Re: Gear box mount
Unread post by spider »
I'd agree the rear one is most likely as it likes to get an oily coating on most diesel models.
You can get the bush and take the mount off and press it in or I think the mount can come with the bush as well for more money.
If it feels "shunty" to power on / off the rear mounting is the first one I'd look at.
Andy.
