C3 Blower Problem!
Hebby
C3 Blower Problem!
Unread post by Hebby »
Ok had my C3 for 2 years now and im the 2nd owner from new and a few days ago had the cold air setting on to blow cold air not aircon just cold and was listening to music when i noticed a vibrating on my leg coming from the dash so pulled up turned music off and noticed the blower making a vibrating noise sort of like a hammer drill but not as loud.
when its on setting 1 its not that noticable but the further you go up IE 2-3-4 the louder it gets and the more vibration there is.
Me personally think maybe a blade from the fan has snapped off but im not 100% so here i am on my first post asking this question.
So does anyone have any ideas on what it is? :evil:
Hebby
Re: C3 Blower Problem!
Nobody have any ideas?
x 5651
Could be leaves or other debris sucked in, although not quite the time of year for that but I imagine your original assessment of a broken blade or support strut to be the more likely reason.
I don't know how difficult it might be to remove the fan unit for examination but can't imagine it being that hard.
x 1480
Hmm, looks like the blower is mounted in the front of the heater box up against the bulkhead. Access probably via the (removed :lol: ) glovebox.... You might be able to reach down the inlet trunk and have a feel, my guess would be it's seizing up, very unlikely to have thrown a blade given the type of unit.
Hebby
Could be a cherry seed as I park my car under a cherry tree and could also be a leaf :?
Think ill park my car later and have a see how easy it is to access the unit :(
addo
Sara Watson's Stalker
x 95
Unread post by addo »
How often do you change the pollen filter?
Hebby
Erm!!!!!
Think it was changed in jan when car went for MOT and service.
krio1987
x 4
Unread post by krio1987 »
Hebby wrote: 26 Aug 2013, 18:28 Ok had my C3 for 2 years now and im the 2nd owner from new and a few days ago had the cold air setting on to blow cold air not aircon just cold and was listening to music when i noticed a vibrating on my leg coming from the dash so pulled up turned music off and noticed the blower making a vibrating noise sort of like a hammer drill but not as loud.
Would love to know if this one was ever solved. I had this all of a sudden. It's been fine since I've had the car and then suddenly started making the vibration noise. Sounds like something is trapped in the fan blades or something. If I run the fan slowly, I can hear something hitting/flapping against something, then When it speeds up it sounds like a hammer drill as Hebby suggests.
I was going to try and locate the fan and change the pollen filter as a good first measure, but throught I'd ask since the original post is almost exactly what I've experienced so maybe this is something that is common.
many thanks
Adam
krio1987
x 4
I managed to sort this one out on my car in the end, I followed the instructions below to gain access to the blower motor.
viewtopic.php?t=70634
I wasn't able to get the motor out since it's pretty tight in there. However, I was able to get it out far enough to see that there was a leaf caught in the blades of the fan. Once I got a pair of tweezers in there, I was Able to pluck out the offending leaf and resolve the issue :)
