Xantia – loose steering
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Since I bought my Xantia ( 2.0 16 v Automatic , power steering ) I have the feeling that the steering is a bit loose. Any hole on the road deflects the steering wheel a bit. I don’t know if that’s normal or not. I also have a C4 at which the steering feels more solid
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: Xantia – loose steering
Any Idea ?
Zohar
lancia58
(Donor 2022)
x 8
Can it be the power steering ram ?
Zohar
Xantidote
x 4
Unread post by Xantidote »
Perhaps a bit of wear in trackrod ends, and/or balljoints or bush(es) in the front suspension?
Martin
1995 Xantia TDLX (deceased :( )
x 1240
Unread post by Peter.N. »
Could be that the tyres are to hard or worn.
oscar
x 8
Unread post by oscar »
Try the void bushes on rear of wishbones turn wheel to left/right then lay down so can see to back of them and see what they look like as they get ripped and each time you move wheel they move back n forth also you get tyre edge scrub also with them gone common problem esp if poor quality or incorrectly fitted ie car not sat squat when lined up as when you press bushes in they need to be so when cars sat right they arn't twisted are they fail prematurely.
Other has as been said lower ball joints also wheel bearings but norm have to be quite bad try rocking front wheel by pushing top of tyre but have to get motion of cars weight going with it then if bearing etc are going you will feel play
But also rear arms can cause what feels like front when on the move esp at speed
lancia58
(Donor 2022)
x 8
The cause is worn steering ram bushes, replaced them and the streening feels much more solid
Zohar
