Hi guys hoping someone can help the turbo on my 06 1.9 dci has started to play up at first it just stopped working alltogether and the fault diagnosis scanner said turbo preassure sensor fault this did initially fix problem but only lasted about a day. Now the turbo doesnt work first thing unless i rev it right up to red line then it only covers about half mile before it decides to go back to sleep so cut engine off and re-start this time without red lining and itll fine untill it sits at tickover (lights etc) then turbo stops working again dashboard says check injection and tickover is a little lumpy but to be honest the injector fault doesnt come up on the scanner.
Ive read through the bol on this and the only thing i can noe put it down to is the solenoid but im someother opinions before i start doing any more on it any help would be great.
1.9 dci tempramentall turbo
Synergietom
Yipee i have the xant lets i hope i keep her this time
steelcityuk
Synergietom
Re: 1.9 dci tempramentall turbo
the only fault code that comes up now ( after changing the turbo sensor ) has been traced back to the dpf allthough the dash doesnt display the clean particle fillter mesage any more since i removed it and ran a jet wash through it.
steelcityuk
Are the fault codes being read by a Renault Clip? A look at the parameters whilst running could point out where to look. It's possible that the ECU isn't happy with the particulate filter or the pressure sensors. What are the readings for the filter?
not applicable
Synergietom
hi sorry not had chance to plug in scanner yet due to working late but no its not a renault clip. Unfotuanately i have had to leave the car at work this weekend as i need the van to move a motorbike ( not mine ) so ill try to finish early monday and get it plugged in
Synergietom
Sorry forgott to mention that it wont rev above 1800 under load and 4000 when sat stationary and then its very lumpy and was like this before we changed the sensor
Synergietom
Well thats it the cat has gone now i was on my way in to work and it and it conked so AA came droped me off at work soaked to the bone and dropped the car off at home for me.
