wheels, tyres, sensors
Stempy
Unread post by Stempy »
A new message has just started to appear on the info screen telling me that one of the wheel sensors is missing. Assuming no one has come along in the night and gone to the bother of nicking it I assume one has packed up doing whatever it does. So is there a way of telling which one?
As it could do with new tyres all round I was also wondering about getting some new wheels to go with them, the standard ones being a bit ugly and stupidly difficult to keep clean. Can the sensors be fitted into any aftermarket wheel or are they a special Citroen fitting?
Lexia ponce
citroenxm
Fallen Hero
x 70
Re: wheels, tyres, sensors
Unread post by citroenxm »
I beleve the sensors are glued on the inside of the Rim, HOWEVER, with the age of your C5, if its a Series 1, you can actually Leagally disable the system. Its only cars sold from 2011 which NEED to have the pressure sensors working..
IM NOT ADVISING YOU TO DISABLE THEM, simply stateing that if they are real headache you can leagally disable them. (With a Lexia Session)
A very sad...
1994 XM 2.1 d auto
Mandrake
x 694
Unread post by Mandrake »
And I would imagine a Lexia session will reveal which of the sensors is the culprit.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Stempy
citroenxm wrote:I beleve the sensors are glued on the inside of the Rim, HOWEVER, with the age of your C5, if its a Series 1, you can actually Leagally disable the system. Its only cars sold from 2011 which NEED to have the pressure sensors working..
Nods as good as a wink to a blind bat......
Lexia ponce
qprdude
x 14
Unread post by qprdude »
Well mine tell me which wheel sensor is showing the warning.
Incidentally, I suspect you can disable any tyre sensor as it has nothing to do with legality. There is absolutely no legal requirement to have sensors so if you wanted to remove them and disable the warnings via Lexia there ain't no law against it.
Rick.
2013 Citroen DS 5 D/Sport
citroenxm
Fallen Hero
x 70
Yes there is.. cars from 2011 if they have them fitted they HAVE to work for the mot..
A very sad...
1994 XM 2.1 d auto
qprdude
x 14
As I said, "if you want to remove them" and disable the warnings. If you remove them, they ain't gonna be fitted.
Rick.
