rev counter wire
john
rev counter wire
Unread post by john »
anyone know what wire is for the rev counter on a mk1 berlingo 1.4 petrol (sagem).
autodata show the ecu as 1 plug where as mine has 3, it shows it as 42 going to 426, where my ecu is a row of letters and a row of numbers.
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Work backwards. Connect one test lead to 426 on the dash plugs and see which socket buzzes out on the ECU connector.
john
Re: rev counter wire
i tried to remove the dash plug but couldn't, didn't want to force anything, seeing as i didnt have the same on the ecu side im not even sure i'd have a 426 on the clock side.
Subaru Impreza WRX
Nissan Primastar
addo
x 95
Try again; it's what you need (blue plug if you have the two plug dash, yellow plug if you have the 5 plug dash). Also it links to the diagnostic socket in many cases (Pin 3).
john
ok will try again.
Subaru Impreza WRX
Nissan Primastar
john
ok, 2 plugs, 1 black & 1 white, 18 pins on each plug (2 rows of 8).
pics shows tach plug and wires
Subaru Impreza WRX
Nissan Primastar
john
sorted, took the feed from the coil pack.
Subaru Impreza WRX
Nissan Primastar
