Looking for a bit of advice here.
I'm investigating the feasibility of a temporary engine ECU swap on my S2 Xantia V6, to try to rule out the ECU as the source of my ongoing intermittent engine running/performance/misfiring issues...
I'm aware that the ECU is paired with the CPH, however I may have access to a pair of ECU's from a donor car that I can borrow for testing.
So my questions are:
1) How hard is it to swap the CPH over ? I know addo has said he can swap one by removing the glovebox, but how exactly is this done and how much work is it ?
2) Can already paired transponder chips in a S2 Xantia be reprogrammed to work with another CPH ? (And then back again later ?) I know they can't be reused on a C5, but can they on a Xantia ? Does anyone know for certain ?
What I would like to do is swap the donor CPH and engine ECU into my car, and use the Lexia to program the donor CPH to recognise my existing RF remote and transponder chips. Is this possible ? Or is it necessary to physically swap the transponder chips in the keys over ?
Any advice gratefully received.
