I wonder how I can remove a xantia mk ii door protector trim - ie on the outside, without breaking the clips and, then replace it.
Is there a nifty method?
Sent from a mobile transmitter.
Door protector trim, safe removal?
John Plum
- x 5
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
addo
- Sara Watson's Stalker
- x 95
John Plum
- x 5
Re: Door protector trim, safe removal?
Cheers Addo - 'due care' , not to be forgotten. !
John Plum
addo
- x 95
John Plum
- x 5
Thanks for very nice tip Addo.
John Plum
Xaccers
- x 188
If you're taking the door card off, you can use a ring spanner (I think 8mm might be about right) from the inside, and as you push it over each peg it squeezes them enough to fit back out through the hole.
DIY sphere tool
DIY sphere tool
John Plum
- x 5
Good idea xac - yes i'll be taking it off to swap round electric/manual window windermechanism - (I have just hung a replacement door in the right colour).
Thanks, John
Thanks, John
John Plum
